troubles with multiplot
Hello every one,
I meet problemes trying to display severals waves on chart :
Here a simplified .vi just to explain my problem , it presents a case of a 3 channels acquisition so the function
array to cluster is set to 3 , so far no problem. But now i would like aquire 2 channels as well as 10 or 50 :
how can i do to obtain a cluster same size as the array dynamically?
Best regards
Tinnitus
CLAD / Labview 2011, Win Xp
Mission d'une semaine- à plusieurs mois laissez moi un MP...
RP et Midi-pyrénées .Km+++ si possibilité de télétravail
Kudos always accepted / Les petits clicks jaunes sont toujours appréciés
Don't forget to valid a good answer / pensez à valider une réponse correcte
(2,635 Views)
Accepted by tinnitus
Look at the CONTEXT HELP on the chart's terminal:
It explains you can use a 2-D array for a multiplot of 1 (or more) points.
Simply use a BUILD ARRAY function in place of your ARRAY to CLUSTER function.
That makes the data into a 2-D array.
The chart knows what to do with it.
Message Edited by CoastalMaineBird on 06-25-2009 07:50 AM
Steve Bird
Culverson.com
LinkedIn
(2,621 Views)
