troubleshoot: in build specifications the new application option is not there
Hi there, I have recently started working with labview 8.2, and when I finished with my .vi I wanted to make an .exe out of it, so I added it to a poject, saved the project, and unfortunately when I right-clicked build specifications there was no new application option. I downloaded run-time engine and it tells me that I allready have it so it is not that. somebody please help me, I'm desperate.
(2,726 Views)
The app builder is not a standard part of Labview 8.2, if you only have the Base Version of LV 8.2 you are required to buy the Application Builder.
Andrew Alford
Production Test Engineering Technologist
Sustainable Energy Technologies
www.sustainableenergy.com
(2,708 Views)
I have the full development version, that is why I dont know why I can't create the .exe
(2,697 Views)
LabVIEW full does NOT include the application builder. You need to purchase the application builder seperately.
Only LabVIEW professional (and higher) includes the application builder.
See https://www.ni.com/en/shop/labview/select-edition.html (look for "Application Distribution").
(The runtime engine is needed to run a built application on a computer that does not have labVIEW installed)
Message Edited by altenbach on 05-01-2007 10:07 PM
(2,693 Views)
