truth or dare- gaming code
how can we create a database or questions { a place where some set of pre-defined data is kept } and also to retrieve information randomly and display n the front panel??
Anyone please help me out in creating a pre-defined database and retrieving that information randomly
Message 1 of 10
(5,001 Views)
You already started down the simple route: use a simple text file.  Each line in the text file should be a new question.  If you right-click on the Read From Text File, you will see an option to "Read Lines".  Enable that and set your number to read to -1 (read all lines).  You will now have an array of questions.
Now you just have to figure out the randomization.  There are plenty of examples on that, but see how far you can get and let us know where you are stuck.
Message 2 of 10
(4,966 Views)
though.. i select read all lines also , the obtained result form the text file to labview is in different language i.e i mean the result is showing in different format not as it is given in the text file also how to obtain randomly those queries from the text file ?? help me out how to randomise if possible provide some info abbout randomisation methods ??
Message 3 of 10
(4,933 Views)
Hi ivan,
Does LabVIEW translate the text from one language to another language? I don't believe this… 😄
Does you text contain any Unicode characters? LabVIEW isn't good at handling such char encodings and reads your text as plain ASCII by default!
(Maybe you should provide your VI and an example text file to help us solve your problem…)
There is a random() function in the numerics palette…
Message 4 of 10
(4,930 Views)
different language means .. there is a different format showing in string (result) indicator
Message 5 of 10
(4,927 Views)
Hi Ivan,
unfortunately I can only open VIs for upto LV2014 right now, so you need to down-convert your VI and attach it again (file menu -> save for previous)…
And please also attach your text file!
Message 6 of 10
(4,925 Views)
here i selected some random question in the text file .. also with previous version vi
Message 7 of 10
(4,921 Views)
Accepted by ivanjoel
Try saving in a text format, instead of a Word format. For example, "t_and_d.txt" with the same data will be much easier to parse.
Message 8 of 10
(4,908 Views)
Greetings !
i would like to select a random line from the given text file without taking the empty spaces .i.e it is taking empty spaces also though i specified read lines in read from text file icon .
Is there any option to make like 'it should only take the lines upto which i specified but not going beyond which results in empty spaces in the display.
Message 9 of 10
(4,857 Views)
I have a VI that specifically goes through the array of strings and removes the empty strings.  This is what I recommend you do.
Message 10 of 10
(4,853 Views)
