turn off control description
Actually, there are differences in Context Help depending on whether you are running the Run Time engine or the Development system. For example, datatypes are not included in the Run Time System. Also the link to expanded Help is not included in the Run Time system, which I do not like. I wanted to link a manual to that link.
mcduff
Message 11 of 15
(1,521 Views)
@RavensFan wrote:
I'm not saying it can't be, but I don't believe that was ever NI's intention..
Someone should probably tell NI that because I've seen it used in lots of their products.
I generally don't do this but think it is a fine use of the Context Help.
Message 12 of 15
(1,513 Views)
According to the video in #2 at http://www.ni.com/tutorial/14131/en/
The user, not developer, is noted when referring to the Description part of the help.
But other documentation suggests the description is for the developer, so it is a bit ambiguous.
mcduff
Message 13 of 15
(1,499 Views)
mcduff
Thanks for pointing that out.  I'm only ever truly working in the development environment so I never really pay attention to the context help in a runtime environment to have noticed that the "programmer info" is removed.
To help answer your original question, what does the context help look like if you happened to just enter a single space in the description field?  What would you want to have seen on the screen for those front panel items with no description?  Since context help is its own entity that is either on or off, while the tip strip shows up and goes away on its own based on what control you are hovering over.
Message 14 of 15
(1,493 Views)
What does the context help look like if you happened to just enter a single space in the description field?
You would still get a pop-up box with either the label or caption.
No pop-up window.
wiebe@CARYA has the best solution. I was hoping there was a property node that I was missing somewhere.
mcduff
Message 15 of 15
(1,480 Views)
