turn off mts310 sensor
Hi all,
I would like to know, if by any chance is there a provision in labview , to turn off a particular sensor ?
if yes how can the same be done ?
(3,190 Views)
That would really depend on the sensor, what it is connected to, and how it's powered. LabVIEW has the ability to control hardware if the ability exists in the hardware itself.
(3,177 Views)
I am currently using MTS 310 sensor , i am using this sensor in various ways.
1. Sensor is connected to the gateway device (MIB 510). ( the sensor is powered by the powered received by the gateway
2. In the second case the sensor is connected in the field ( xmesh network) with more than 1 hop.( powered by a batterry mounted on a mote.
thanks
(3,173 Views)
Sorry, I'm not at all familiar with wireless data acquisition. I thought you might be talking about sensors connected to an NI DAQ board.
(3,164 Views)
Hey anilhk,
The LabVIEW driver for Crossbow wireless sensor networks does not have any functionality to turn off a particular sensor. There is no functionality to send any sort of command to any node, only to read data from a node.
Chris Delvizis
(3,144 Views)
