turning a 3D array into a 2D array
Hi, is there a way to turn a 3D array (containing 4 pages of data, 4 rows each) into a 2D array of 16 rows of data? i have tried the reshape array, however when i wire in the 3d array into it and constants of 0 and 1 the 2D array i get out has only 2 elements.
i need to manipulate data using mathscript and do comparisons withinthe rows, so its important to havethe data in a way that mathscript can recognise.
thanks a lot.!
asiri
(6,430 Views)
Hi Radioman00
You can try this code:
Then you should get that what you want to have.
Try and tell me if it worked.
raphi
(6,423 Views)
Accepted by Radioman00
You can wire (pages x rows) to the first dimsize input of Reshape Array, and wire columns to the second dimsize input of Reshape Array.
帖子被DSPmchen在 08-13-2009 04:43 AM
时编辑过了
(6,422 Views)
i managed to solve it, tho i don't know how efficent my method is compared to others, i am fairly new to labview.
thanks a lot for the suggestions! 🙂
(6,390 Views)
sorry DSP, didnt realise that you had presented the same solution. Thanks!
(6,374 Views)
For my purpose its work perfect! Great! Thanks a lot !
(4,818 Views)
