tv signal processing
Hi there, sorry for our last post; we are  noobs at posting ^^
We need to use a parallel port on a computer as data input, since we havent found any direction or advise, or just couldnt find it, we were looking for some help.
We have a "TV pattern generator" and a licensed Labview
1) Is there any VI or similar for labview that uses parallel port as data input?
2) Can we generate tv signals, simple pattern signals like circles  or squares in labview?
Thanks a lot
Mensaje editado por laboratoriotv
(3,235 Views)
Yet another duplicate post!
(3,218 Views)
Hello there. As for your question regarding the data input as parallel port, it is quite easy to achieve this: I send you some information on the parallel port and a VI that outputs the signal through the parallel port. The idea is pretty much the same if you wish to input the signal, you'll just have to use the opposti function (In Port).
Some of the info is in Spanish, but you may find the diagramas useful.
Ali.
Message Edited by Ali84 on 11-21-2007 09:39 AM
(3,215 Views)
Thanks ali.
We are very happy with your information.
 Do you speak spanish?
please if you have  more information about this please send it in spanish.
thanks again. Smiley Wink
(3,206 Views)
