03-02-2015 10:39 PM
How to make two input of table X and Y will be automatically make the table Z is the output and it will be display in indicator C
The value of X and Y is depend on Enum A and B as shown in figure
03-02-2015 10:44 PM
Divide array Y by 10 and add to array X and you've got array Z.
How do you want to show that in C which is a scalar indicator?
Controls A and B are not enums, they are just double floating point controls.
What is up with the rest of the controls and indicators?
03-02-2015 11:24 PM
sorry for wrong enum.
how to make for example if input control A is 6 and B is 6 then the value Z is 6.6 as shown in table. this value 6.6 will then multiple with E and D as in firgure.
03-02-2015 11:31 PM
A + B/10
03-03-2015 12:52 AM
farah88, what exactly are you trying to achieve? RavensFan's answer (A+B/10) is the obvious answer to your question but I doubt that is what you really want (are the values in your picture just for example? - surely both arrays are not going to be 0 to 6 or you would just have one array?)
Can you explain why you want to do this so we can understand exactly what it is you want?
Stu.
03-03-2015 02:24 AM
no, its just example.
I want to make if let say the value of A is 2.2 and B is 4.5 (this both value is assume to be input by user) then the value of 7 of Z table is automatically used.
like formula below (E + D) * (table Z)
03-03-2015 02:25 AM
03-03-2015 02:47 AM
03-03-2015 03:16 AM
Sorry,
the array table above is constant. user will enter value based on table given (hardcopy)
the value of table Z is depend on the both value A and B of table X and Y.
I means A= 1 B=1.5 ~ table Z=1
A= 1.2 B=2.5 ~ table Z=3
A= 2 B=3.5 ~ table Z=5
A= 2.2 B=4.5 ~ table Z=7
and so on.
03-03-2015 03:32 AM
Suppose, If user is giving A=2 & B= 2.5, What is the Z value?
