two version of LabVIEW installed. Unable to open older VI's with older LabVIEW
I currently have LabVIEW 6 and LabVIEW 8.5 installed on my PC running Windows XP. When I try to open an older VI via LabVIEW 6, I get the following error message:
An error occurred loading VI 'Global-file paths.vi' LabVIEW load error code 9: VI version (8.5) is newer than LabVIEW version (6.0).
I'm trying to open a (dll) file with LabVIEW 6. I recently upgraded the labVIEW version to 8.5, but now i'm unable to run the older VI's in either version of LabVIEW.
What should I do?
Message 1 of 9
(3,795 Views)
That error is the classic "I opened a VI in a newer version and saved.  Oops.  I wanted to keep it in the newer version."  I would think you should still be able to open it in LabVIEW 8.5 though.  If you switch between versions a lot, you need to be very careful which version opens a VI.  I recommend having 1 version of LabVIEW open at a time and only try to open a VI when you have the right version opened.  Otherwise whatever version you used last will try to open the VI.
GCentral
Message 2 of 9
(3,792 Views)
You CAN always restore the 6.i vis from your source code control repository can't you?
Spoiler
Oh boy I hope they have a source code repository-  that could get very ugly otherwise.
Message 3 of 9
(3,776 Views)
I haven't made a source code control repository.
When I try opening the VI with LabVIEW 8.5 I get the following error:
Error Loading 'C:\Program Files\National Instruments\LabVIEW 8.5\vi.lib\lvdaq.dll" A dynamic link library (DLL) initialization routine failed.
When I try opening the VI with LabVIEW 6 I get The following error:
Sub-vi is not executable. The Error list then says that "Call Library Function: function not found in library. However when I get to the configure the library screen the Library Name or Path is correct. Attached is a screen shot.
What is the best way to approach this problem?
Thanks in advance.
Message 4 of 9
(3,763 Views)
The error is not saying the path is incorrect. It is saying the function was not found. What version of the driver is installed? Try doing a repair or reinstall.
Message 5 of 9
(3,760 Views)
If I choose to uninstall LabVIEW 8.5 leaving only LabVIEW 6, will the problem be fixed?
Message 6 of 9
(3,716 Views)
Have you tried reinstalling the traditional DAQ drivers? See also.
Message 7 of 9
(3,706 Views)
Yes, i've reinstalled the traditional DAQ driver ( Traditional NI-DAQ (Legacy) 6.9.3) and I'm still having the same error.
Message 8 of 9
(3,698 Views)
"The Problem" is thsat you saved the vi while editing it in LabVIEW .8.x  LabVIEW 6.i cannot possibly know what software from a decade into the future means.  Post your busted vis over to the version conversion board.  AND GET a repository set up.
Message 9 of 9
(3,675 Views)
