txt string spreadsheet
Hi :
i have txt string and i want to spread it to array
for example my txt string is like the
Power Off,0.00,0,0,Volts,Pass
Relay Init,1.00,1,1,,Pass
Power On,12.00,11.8,12.2,Volts,Pass
-- Result Pass (59/0)
and i want to each raw insert to array\record like this
index 0 = Power Off,0.00,0,0,Volts,Pass
index 1=Relay Init,1.00,1,1,,Pass
index 2=Power On,12.00,11.8,12.2,Volts,Pass
index 3=-- Result Pass (59/0)
how can i do that in labview
(3,242 Views)
Take a look at the code i have attached .. This will solve your problem.
Nitzz
(Give Kudos to good Answers, Mark as a solution if your problem is Solved:smileywink:)
(3,233 Views)
Hi Elyan wisam,
see the "Spreadsheet String to Array" function. It's located in the string palette.
Mike
(3,229 Views)
Hey Elyan
As Mike wrote this is what you could do.
stringToArray
If you want to load your string input from a txt file you need to use the read txt file subVI in the File I/O palette.
Sletten
(3,224 Views)
Hi Mike,
Thanks for this solution.. I didn't think about this simple solution..:)
Nitzz
(3,222 Views)
