unable to establish serial connection between 2 serial ports of same laptop
I am trying to run "Basic 2 port serial write and read.vi" from the labview example using the 2 different com ports of same laptop. My serial cable is fine. It has passed loopback test. Also I have successfully communicated with the microcontroller(via max232) using the same cable. Still In the given example, I am not recieving character that I have written in the "string to write" window. I have confirmed the com port numbers. The cable I am using is simple 3 wire tx-rx and ground cable. I have also tried to connect two ports on two different pc's that also doesnt work. What may be the problem? I can't see any.
Message 1 of 26
(4,210 Views)
Post your VI friend. This will help us to debug the problem better.
VI in 2011 compatible format Smiley Very HappySmiley Very HappySmiley Very Happy
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
Message 2 of 26
(4,201 Views)
Is the cable a straight through or a NULL Modem?  You will need a NULL Modem cable which means that the TX on one side is connected to the RX on the other side and visa versa.
Message 3 of 26
(4,195 Views)
The .vi given in the labview example "Basic two port serial write and read". I am using two usb to db9 convertor to convert my usb port into com port. and then connecting both of them with crossover serial cable.but nothing can be recieved at the read window and timeout occurs.
Message 4 of 26
(4,190 Views)
tx to rx , rx to tx and ground to ground confirmed
Message 5 of 26
(4,188 Views)
2011 compatible please
--Ranjeet
Message 6 of 26
(4,180 Views)
Are you changing the data being sent?  As currently configured, you need to make sure the \n stays at the end of the data.  To avoid this, turn the termination character off (input on the top of the Configure Serial Port, wire a FALSE constant to it).
Message 8 of 26
(4,167 Views)
still no success 😞         In fact i can't establish communication between two different applications also. i.e between hyperterminal to labview, between labview to matlab etc..
Message 9 of 26
(4,162 Views)
1.Which 3rd party software you are using for USB to db9 conversion.
2. In both the PC labview is installed ?
--Ranjeet
Message 10 of 26
(4,159 Views)
