une tempo a l’allumage d’une diode , ou a la mise a 5v la sortie DAQ PO5 de l’USB-6009
Bonjour
      Pouvez vous me conseiller, ou me donner un  exemple sur la façon de réaliser une tempo a l’allumage d’une diode , ou a la mise a  5v la sortie DAQ PO5  de l’USB-6009
Merci
(2,634 Views)
Accepted by THIERY
You're in the English section of the Forums so please write in English.
In you want to post in French, please post here :
http://forums.ni.com/t5/Discussions-au-sujet-des-autres/bd-p/4170
What do you mean by realizing a temporization? Do you mean timing? Would you like to light on a LED during 5sec?
Please explain.
Jérémy C.
NI France
(2,613 Views)
Hi
Tanks for  reding mi , i was not able to continue the solving  of the question,Please excuse me for not giving any signed hove respond
Regards
(2,530 Views)
I am sorry that you have not been able to get a solution on the French forums. Are you still looking for an example for writing a 5V output from your USB-6009? You can try going to the NI Example Finder by going to Help >> NI Example Finder and navigating to Hardware Input and Output >> DAQmx >> Analog Output and choosing one of the examples there. They use different signal types, however you can change these examples to fit your need. Also, here is a link to an example that does essentially the same thing as the examples in the NI Example Finder, but use a ramp function specifically:
https://decibel.ni.com/content/docs/DOC-14687
Thanks!
Stephanie S.
Application Engineer
(2,503 Views)
