une tempo a l’allumage d’une diode , ou a la mise a 5v la sortie DAQ PO5 de l’USB-6009
Bonjour
      Pouvez vous me conseiller, ou me donner un  exemple sur la façon de réaliser une tempo a l’allumage d’une diode , ou a la mise a  5v la sortie DAQ PO5  de l’USB-6009
Merci
(2,669 Views)
Accepted by topic author THIERY
You're in the English section of the Forums so please write in English.
In you want to post in French, please post here :
http://forums.ni.com/t5/Discussions-au-sujet-des-autres/bd-p/4170
What do you mean by realizing a temporization? Do you mean timing? Would you like to light on a LED during 5sec?
Please explain.
Jérémy C.
NI France
(2,648 Views)
Hi
Tanks for  reding mi , i was not able to continue the solving  of the question,Please excuse me for not giving any signed hove respond
Regards
(2,565 Views)
I am sorry that you have not been able to get a solution on the French forums. Are you still looking for an example for writing a 5V output from your USB-6009? You can try going to the NI Example Finder by going to Help >> NI Example Finder and navigating to Hardware Input and Output >> DAQmx >> Analog Output and choosing one of the examples there. They use different signal types, however you can change these examples to fit your need. Also, here is a link to an example that does essentially the same thing as the examples in the NI Example Finder, but use a ramp function specifically:
https://decibel.ni.com/content/docs/DOC-14687
Thanks!
Stephanie S.
Application Engineer
(2,538 Views)
