unexpected blank cells in the spreadsheet file after writing
I am trying to write dummy data to excel file and notice that there are blank cells in the file like below. How could I prevent this?
10:10:07 10 0 1 2 3 4
10:10:07 20 0 1 2 3 4
10:10:07 30 0 1 2 3 4
10:10:07 40 0 1 2 3 4
10:10:07 50 0 1 2 3 4
Egemen
Message 1 of 10
(4,366 Views)
Which one you are calling as Blank cell? I don't see anything, also the code and the file you have shown matches. Please explain the exact problem
Message 2 of 10
(4,365 Views)
Yes I got it. You mean to say the empty row,  you can clear that by inserting Trim Whitespace.vi at the output of the Array to Spreadsheet string primitive.
Message 3 of 10
(4,356 Views)
Thank you for your answer. But is there another way to do it? Because this function is only accept string inputs instead of arrays both 1D and 2D so I need to use it after all my string before the build array function. It is too time consuming for large data sets.
Edit: Sorry I did not understand your suggestion in the correct way. I opened the write to spreadsheet function and add this trim function in the place that you pointed but it does not affect the file.
Egemen
Message 4 of 10
(4,353 Views)
Accepted by newbieeng
Did you do this way?
Message 5 of 10
(4,349 Views)
Ohh... I placed it in the wrong way. IAll blank rows are dissapeared after this modification. Does only this section cause the blank rows and why?
Egemen
Message 6 of 10
(4,343 Views)
You can check the help file of the Array to Spreadsheet string function, it shows always a EOL (End-of-Line) character will be added to seperate the rows. You had two because you are using one and the write to spreadsheet vi uses one.
Message 7 of 10
(4,338 Views)
I have also another problem about leaving rows in spreadsheet blanks. I tried to explain what the problem is in the attachment. Could you help me on this?
Egemen
Message 8 of 10
(4,318 Views)
An empty array will not produce any output.
If you want to generate a zero-filled table you need to create an array with as many elements as needed, using for example the Initialize Array function.
Paolo
Message 9 of 10
(4,300 Views)
Oh right. I have forgotten to fill it. Thanks 😄
Egemen
Message 10 of 10
(4,294 Views)
