unexpected error nigpibsys
After a long time I haven't used Labview, it gives me this error.
Which software need to be uninstall & install in order to solve this problem?
Shall i uninstall the whole software?
thanks
(3,893 Views)
See here
Then find out what hardware is attempting to enable physical address extension on your OS.  There are details on how to dissable the PAE for several OSs.
(Side note:  Did you see that link to NI.Com/Info and the code to search for right at the top of the error dialog?)
(3,880 Views)
hi Jeff,
The page you suggested that we disable PAE.
I have searched the system log but no PAE is found in the event list.
The software & hardware worked a while ago. Win 7 - 64 bit, but I installed labview 32 bit.
Any other suggestion?
Really appreciate your help though.
(3,872 Views)
Hi Tony,
This is not a LabVIEW error, but rather an Internal Warning from the NI Measurement & Automation Explorer (MAX). More often than not, MAX internal warnings should not affect your functionality in LabVIEW. However, repairing an installation, or uninstalling/reinstalling software is certainly a good step to take when troubleshooting. NI MAX is installed along with hardware drivers (NI-DAQmx, NI-VISA, etc.), therefore you may want to begin by repairing your driver installations. It looks like the MAXKnownExceptions info code links you to this KnowledgeBase Article:
Causes of an "Unexpected Error" from Measurement & Automation Explorer (MAX)
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019MV8SAM&l=en-US
Hope this helps!
Cameron Schaefer
Applications Engineer
(3,805 Views)
