uninitialize shift register
Hallo,
I would like to ask a question about the uninitialize shift register. I would like to use a uninitialize shift register in a subvi in order to pass data between subsequent calls of the subvi.
The problem is that the data i would like to pass is a 2D array.
The labview seems not to accept 2D array data type in uninitialized shift register.
Can someone please help me?
thank you.
Message 1 of 9
(4,907 Views)
Hi achille,
what do you mean? It works great.
Mike
Message Edited by MikeS81 on 06-06-2008 12:06 PM
Message 2 of 9
(4,905 Views)
Thank you for your answer.
if you do not use the 2d array in the while loop but a 2d array is coming from the left shift register use then initialize a new small array and then put it in a larger one and then connect the output to the right shift register there is a problem.
Message 3 of 9
(4,897 Views)
Hi achille,
i can´t see it. Can you upload your example?
Mike
Message Edited by MikeS81 on 06-06-2008 12:39 PM
Message 4 of 9
(4,893 Views)
Is a small block diagram just made to see what i mean
if in my block diagram just delete the 2d array that is connected to the left shift register so as to be un initialized then the array automatically is converted to 1d array. just try it. it doesn't look to keep the 2d data type
Message 5 of 9
(4,885 Views)
Hi achille,
ok, but where is the problem, it shows only that the "insert into array" function don´t dictate the array size. Smiley Happy Where do you need it? One solution is to insert a case structure inside the while loop. Insert your code into the true case and an array constant into the false case. Connect a true to your case structure and you have what you want. But remember use a boolean control or a shiftregister value! If you connect a constant, then labview know that this case will never be execute.
Mike
Message Edited by MikeS81 on 06-06-2008 01:01 PM
Message 6 of 9
(4,879 Views)
Thank you MIke. I haven't thought such a solution. I was thinking that other was the mistake for not accepting a 2d array.
Thank you. I will do it according to your suggestion.
Message 7 of 9
(4,872 Views)
Another option is to use the First Call? vi under Synchronization.  It will return a True if this is the first time this VI is called in memory, and a false otherwise.  Then, in your True case, you can initalize the register in the while loop, and in the false you can do everything else.
Message Edited by JeffOverton on 06-06-2008 07:51 AM
Message 8 of 9
(4,863 Views)
Are you familiar with Action Engine(s) and Functional Global Variables?
Do a search of Action Engine, you may discover more about what you want to accomplish. 😉
RayR
Message 9 of 9
(4,857 Views)
