uninstall labview 32bit version and keep 64bit version
How do I uninstall the 32bit version of LV2009 and keep the 64bit version operational?
(4,759 Views)
Have you tried to simply uninstall the 32-bit version? You know, Add/Remove Programs (on Windows), and select "National Instruments Software". I am assuming you have LabVIEW 2009 or higher? The 32-bit and 640bit versions should be listed separately.
(4,744 Views)
I'm concerned that there are shared components and the 64bit version will get wacked.
(4,735 Views)
Accepted by topic author SciDesign
Labview 64bit and 32 bit versions are indipendent. It is important to note that not all modules are 64 bit compatible.
Below are a few web pages with FAQs on the differences between labview 64bit and 32 bit.
https://www.ni.com/en/support/documentation/supplemental/09/using-national-instruments-products-on-3...
https://www.ni.com/en/support/documentation/supplemental/18/labview-32-bit-vs--64-bit-applications-f...
(4,723 Views)
