uninstall labview trial 8.6
     I have installed the Labview 8.6 trial version. My trial license expired. The issue is that I need to uninstall the labview trial version (in windows XP). When I use control panel, it fails. When I use the labview installer/modifer that the program used to install itself, it fails. How do I remove this program from my computer completley (files, registry settings, etc.)?
Thank you for your assistance.
(5,182 Views)
You should contact National Instruments; they have some utilities and procedures in place to remove NI software and references from your computer.
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
(5,178 Views)
Accepted by topic author Al996
Hi AI996,
Thanks for your post and I hope your well today.
If the add/remove programs didn't successfully uninstall LabVIEW. Then you could try using the MsiBlast.exe.
Link:
http://forums.ni.com/ni/board/message?board.id=250&message.id=12643&requireLogin=False
Just make sure you don't have it open or any code running (check Task Manager to make sure no LabVIEW tasks are running).
Hope this helps,
Adnan - keep up the good work 😄
Kind Regards
James Hillman
Applications Engineer 2008 to 2009 National Instruments UK & Ireland
Loughborough University UK - 2006 to 2011
Remember Kudos those who help! 😉
(5,128 Views)
