unknown sql error
I'm trying to pull a specific instance from a table and i'm receiving an error with no description. Any Ideas?error.JPG
Message 1 of 9
(4,714 Views)
Turn on highlight execution to check which VI is throwing the error (I am thinking it's the first). Have you checked whether you successfully established a connection between LabVIEW and the database?
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
Message 2 of 9
(4,711 Views)
The error is being thrown by the execute sql query function. So i think there might be some very small mistake with it, but i don't see one. The column i'm checking is a string. Both the table and column i'm searching are correct.
Message 4 of 9
(4,705 Views)
But what column do you want data from ?
You need to specify a column to get data from in your select.
SELECT columnName FROM table1 WHERE ... or
SELECT * FROM table1 WHERE ...
Message 5 of 9
(4,692 Views)
Even if i specify which column to put it in it still has the same error.
Also nyc,
Message 6 of 9
(4,683 Views)
Accepted by Fulmetalal
Change the column name. It seems that Current is reserved.
Message 7 of 9
(4,671 Views)
Thanks, you saved me a couple days of headaches trying to get it to work.
Message 8 of 9
(4,666 Views)
Sometimes you can work around reserved names by putting the name is square braces.
For example: [Current]
Message 9 of 9
(4,659 Views)
