update a table content in database MS access
Hi
In my application i am using Database toolkit to write a table in to MS access.
i am able to write a table in to database but i am facing problem in editing a perticular cell in a table which is there in data base, how this can be achieved?
When i use insert data vi, a row of data is being inserted. but in my application i need to keep updating the data in the same field.
Ex: If i have writen a data in the 1st row i should keep updating the values of the 1st row basically i need to edit table contents.
regards
anil
(4,719 Views)
Anil
You can DB Tools Execute Query to run an UPDATE query. Take this example where I use the example labview.mdb database in ...\examples\database directory. This VI allows the user to UPDATE the PhoneNumber field for record with CustomerID=23311 which is the first record.
Hope this helps
David
Message Edited by David Crawford on 10-07-2006 09:37 AM
(4,716 Views)
Alternatively,  this link http://zone.ni.com/devzone/cda/epd/p/id/3150 that demonstrates how to update a database table using the DBT
I followed a lead on another post and found the above link which I didn't know this existed until now.
Still learning ....
David
(4,710 Views)
Hi David
Thanks for the help when i use in my code its throughing an error
Exception occured in Microsoft JET Database Engine: Syntax error in UPDATE statement. in Conn Execute.vi->db write.vi
(4,684 Views)
Which one doesn't work?
I tested my first suggestion but didn't try the second.
David
(4,678 Views)
David,
i have solved the problem thanks again
regards
anil
(4,676 Views)
