updated presettable up/down counter VI request
 The previous post regarding presettable up/down counter should have included the following information.
 I am using a digital input card and do not have access a multifuntion card nor counter card.
Has anyone created a VI for LabView that implements the following capability.
   Read logic level from a digital I/O board that have inputs A,B,and I from a incremental shaft encoder to determine shaft position. The encoder output 200 steps per rotation. Therefore, the counter needs to have the capability to be set to 199 if the shaft rotates ccw three degrees from home.
   The counter increments with a clockwise movement and decrements with a counterclockwise rotation.
   I will greatly appreciate any suggestions
(2,538 Views)
Keep following this thread here
(2,535 Views)
