09-14-2006 11:21 AM
Read logic level from a digital I/O board that have inputs A,B,and I from a incremental shaft encoder to determine shaft position. The encoder output 200 steps per rotation. Therefore, the counter needs to have the capability to be set to 199 if the shaft rotates ccw three degrees from home.
The counter increments with a clockwise movement and decrements with a counterclockwise rotation.
I will greatly appreciate any suggestions
09-14-2006 11:25 AM
