updates the chart on web publishing tool
Hello, Everyone.
         I have a question, that I was trying to use Web Publishing tool to publish a running system. I am able to run it and display it. But the situation right now I met is that the chart and all the data are static, You can only update it whenever you refresh your webpage.
         Did I forget to specify some features about this application? Thanks for any kind of suggestions.
(3,365 Views)
What viewing mode did you select?
(3,359 Views)
Monitor Mode, with 5 seconds time interval for refreshing.
(3,346 Views)
(3,343 Views)
Use Embedded if you want a continuous update that does not require any action on the client side to see the latest data.
(3,341 Views)
