change the color?
hello again
I have a simple question
if we have arrays, boleans , strings, graphs and many other things....  on the front how can we make them invisible(unseen as if their is nothing their )for some short time?  Is there any relation  this with the property node?
thank you very much
merci
Message 1 of 14
(3,783 Views)
Yes, there is a relationship to the Visible property node.Smiley Wink
Message 2 of 14
(3,782 Views)
This thread is strongly related to this question Smiley Wink
Message 3 of 14
(3,763 Views)
hello
Well my question is not related to changing the color of the front panel and its constituents but I was aking how can we make all the things in the front panel invisible for some time that is if we had a bolean indicator, we may be able to make it disappear for some period of time.
thank you very much
merci
Message 4 of 14
(3,745 Views)
Hi sombarero,
your both questions can be reduced to "How do I change properties of front panel objects?" - and the answer is "Use property nodes of the objects!"
In this way both threads are strongly related Smiley Wink
Message 5 of 14
(3,738 Views)
Accepted by topic author shrek'sdonkey
Try this (LV86).
Jean-Marc
Message Edited by J-M on 12-13-2009 10:33 AM
Message 6 of 14
(3,729 Views)
Thank you very much J-M I appreciate your kind help thank you very much it is the real solution
Merci
Message 7 of 14
(3,719 Views)
hello J-M  thanks for your generous help  I used for vi but I had a problem in the property node of class panel and type visible  (it is not like yours)  could you show me how you did it please
merci
Message 8 of 14
(3,687 Views)
Hi shrek,
you already got an example from JM. What exactly is your problem?
Do you want to make the front panel invisible? Then use the State property of the front panel.
What do you mean by class and type? In LV we only have frontpanel elements and their properties - no classes, no types (atleast not in this context)...
Message 9 of 14
(3,678 Views)
Post what you have done.
JM
Message 10 of 14
(3,677 Views)
