change the color?
well this this want I done after your help
Message 11 of 14
(601 Views)
What version of LabIEW: Base, Full,...?
Message 12 of 14
(595 Views)
labview 2009 evaluation
Message 13 of 14
(589 Views)
That VI makes absolutely no sense. Why do you have a constant of 2147483647 wired to the N terminal of the loop? Are you trying to run the VI for a really long time? Inside the case structure you do not need the "visible" local variable - use a wire to read directly from the terminal. Why are you navigating the front panel hierarchy? Just right-click on the control that you want to set a property on and select Create -> Property -> (choose your property). This will create a property node to place on the block diagram.
Message 14 of 14
(584 Views)
