08-07-2015 03:38 PM
What is the best way to update an old DAQ iterface to LabVIEW 2014. I imagine I should use DAQmx fuctions but it just isn't working out for me. Any information or resources would be greatly appreciated. I've attached the old back panel as well as the imported version
Thank you.
08-07-2015 04:25 PM
Looks like the program is using traditional DAQ. (If your windows version is 32bit, you might get it to work, but it is probably better to upgrade)
08-07-2015 05:17 PM
yes, I want to upgrade. unfortunately the vintage DAQ is no longer available in 2014. how would I start rewritting this section?
Thank you
08-07-2015 05:39 PM - edited 08-07-2015 05:42 PM
Did you look at the link I provided?
And yes, you can download them here. (as I said, they require 32bit windows).
08-07-2015 06:37 PM
Thank you, I'll take a look at that
