updating dynamiclly subvi indicator in main
I've learned to parse a string in general,however, why does main vi update after subvi is finished? Solution for problem? see attached. thankz
(2,780 Views)
A subVI is not supposed to return values until it's done. That's the way it works in other languages as well. There are ways to update the main while a subVI is executing but I think the biggest problem is that your subVI is just slow and ineffecient. From your post in another forum, I've modified your VI to do it a little differently and get the results that you said you want.
(2,775 Views)
Thanks Dennis, trying to spend this week to get more familair with lv
(2,769 Views)
