upgrade whole library from LV7.1 to LV2011
i am using an evaluated LV2011 version and want to convert (after making a backup) my library of .vi's. Since it is quite a lot, I wanted to ask for a convenient and fast way to do this, instead of opening each .vi seperately.
Thanks for help,
Daniel
(2,470 Views)
there is a thread about upgrading HERE
I think you will have more chance to have an answer...
V-F
(2,464 Views)
Daniel,
i think this link is also of interest for you. I am under the impression that you can open LV 7.1 directly in 2011, so you should not need interim versions of LV.
So a "simple masscompile" should do the trick, but please take care of the notes given in the link above.
thanks,
Norbert
Norbert
Expert: Geometry
(2,459 Views)
