This widget could not be displayed.
upload a bmp image via FTP
Probably someone asked the same question but I want to upload a bmp image available through FTP into labview and use it with the Vision Vi's. How can I do it ? Especially convert the data output of the get FTP Vi into an image   Thanks
(2,941 Views)
Dear dillen,
isn't the following any solution? Using "FTP Put file" and "read BMP file":
Cheers,
(2,874 Views)
Finaly I found a solution with a copy of the data to a temperary file. I will try your solution.
(2,847 Views)
The same with the image.
I used getFTP   Open/create..File    write to binary file
(2,844 Views)
