urgent help needed:saving serial port data in multiple txt file
@lm35 wrote:
now for the code should i use  a peoperty node inside the for loop or while loop, or any other ways to store the adc vaues in txt file, any code correction or code would be helpful.
No, you should not be using the Bytes At Port property node.  You need to follow the protocol that the micro-controller is using to send the data.  Otherwise you will get bad values.
Message 11 of 18
(1,626 Views)
Thanks dude.
what should i do with the for loop(for visa read) should i remove or replace it with a while loop with delay inside or simply put in a case structure something like that.
Message 12 of 18
(1,620 Views)
Accepted by topic author lm35
Hi "dude",
please keep "technical" questions in the public forum…
Try this:
You really need to define/explain the formatting of the strings/data you receive from your device!
(And please stop calling everyone "dude". We all use nicknames, some of us also write their first name.)
Message 13 of 18
(1,605 Views)
Again, WHAT IS THE PROTOCOL OF THE MESSAGE DATA?  We cannot give any real help without that information.
Message 14 of 18
(1,593 Views)
Dear Mr GerdW,
Thanks for the help, the code is working now.
Message 15 of 18
(1,548 Views)
Dear Mr GerdW, In this code i am having some timing problem, after running some time i am getting corrupt data means the flow of data is not constant and after i have created around 10000 files the flor loop counter is not running to 304 instead it running to some ranndom no.plz help i am attaching mz code
Message 16 of 18
(1,520 Views)
format of data
Message 17 of 18
(1,519 Views)
Message 18 of 18
(1,517 Views)
