usb 6210 analog voltage reading problems
I am trying to wirte a program that will read multiple voltages or currents from single wires so that I can maximize channel use on my usb 6210. I have an external power source, your basic DC power supply. I wired it to NRSE configuration such that the voltage sources that I would like to measure are sometimes connected to DC+ from the power suuply (trying to measure when these connections are made by an insect) and come into terminals AI0-AI15, with AISENSE returning to the DC- terminal on the power supply. As far as I know, there are no ground loops in my system, I have thoroughly read the field wiring manual. Right now, only 8 of the 16 AI terminals are wired, you will see in the block diagram.
Here is my issue: when one of the inputs is connected to the power source (running approx. 2V), all of the other waveforms are strongly affected. Attached images illustrate this. I need independence between my channels so that when one wire is connect the other waveforms don't jump with it. I would really like to see distinct waveform patterns triggered by the connection, which will have varying degrees of resistance depending on what the insect is doing.
I am on XP and I saw some MS hotfix for potential usb data problems referenced in MAX, but I don't know if this is the problem I have, the hotfix link tells me its unavailable.
Any guidance in this matter would be much appreciated.
(2,562 Views)
If you are seeing signals on unconnected channels, that is normal and is called ghosting. Please search for that.
(2,539 Views)
I found lots of info on ghosting. How to apply this knowledge to my problem is another matter. I see that I need to slow my sampling rate, and I found the DAQmx timing property node but I don't know how to apply this in my block diagram. Also it looks like creating dummy channels would be a good way to go but I cant get this to work either.
Thanks.
(2,521 Views)
