usb interrupt timeout event handling
Hi all,
I am new to labview, I am doing PIC and PC USB data transfer. I am wondering is there any way I can handle the timeout event generated by "VISA wait on Event" VI, so that when there is no coming data within certain time, it would continue proccess other code rather than generate a error. I am thinking of why VISA USB intterupt has a timeout. Interrupt can only be trigger whenever it is requested, any method to link a USB interrupt event to EVENT Structure rather than polling, which makes more sense to me.
Thanks & Regards
Message 1 of 8
(5,144 Views)
Could anyone help please?
Message 2 of 8
(5,139 Views)
No text needed, please check out my sig.
Shane
Message 3 of 8
(5,133 Views)
what do you mean?
Message 4 of 8
(5,127 Views)
Difficult to understand your message and could you elaborate to it more exactly to problem.
Message 5 of 8
(5,122 Views)
Intaris means check out the USB nugget links in his signature. They take you here and here. There is some great information there about using VISA with USB. Kudos Intaris!
John B.
Embedded Networks R&D
Certified LabVIEW Developer
Message 6 of 8
(5,115 Views)
Accepted by Peter Huang
Yeah, sorry for being so cryptic.
I indeed meant the USB nuggets linked to in my signature.  I assumed once I had mentioned it they would be found.......  Sorry.
You should find an example of using Interrupt functions in there.
Shane.
Message 7 of 8
(5,104 Views)
Thanks guys. I got the idea.
Message 8 of 8
(5,085 Views)
