usb printer
Finally a modicum of success!!!!!!!!!!!
Smiley Happy
Now is there a way to configure it so it doesn't give me a mile of blank paper at the end?
I've been getting a little cranky working on this problem.  Thanks for putting up with me!!!
Mike
Message 11 of 16
(1,444 Views)
I woul suggest making the subVI's front panel as small as possible and then experimenting with the settings. It has been a little while since I did this and I don't remember the details. There may be printer settings that might also need to be changed.
Message 12 of 16
(1,441 Views)
configured it for a 6 3/4 envelope.  Nice and short printout.  I'm using this to print a repair ticket.  Thanks!!!!!
Mike
Message 13 of 16
(1,439 Views)
Next Question:  Is there a way of specifying the print destination?
Mike
Message 14 of 16
(1,427 Views)
There is the application property called Default Printer. Is that what you mean?
Message 15 of 16
(1,424 Views)
That would work.  The usage I am leaning toward would be to configure it so it always print to a printer device named Repair Ticket, and then it has to be configured for a certain size paper, etc.  Not very flexible.
Mike
Message 16 of 16
(1,419 Views)
