use of Advantech PCI card on LabVIEW
Hi all
 I want to use Advantech PCI-1712 card on Labview,  the driver of this card is already installed. Does
anyone have some Example VIs and Application notes of how to use the Analog and Digital I/Os of this
card on labview? If yes ,Plz send.
Basically, i want to use the two Analog outputs of this card for generating two sine waves. One sine wave
has the fixed amplitude and frequency and the other sine wave should have the controls provided on the
front panel to control its amplitude and phase shift with respect to the other. If anyone has generated the two
waves from two analog outputs of this card then please give me the suggestions of how to do it.
Please send me any VI on this or any application note on this. I have already read the help , but still concept
is not clear.
Any help will be greatly appreciated.
Regards
(5,153 Views)
Have you tried contacting Advantech?  They list "Rich examples speeding up your programming" as a feature.  You could ask them for those.
Justin Parker
Product Support Engineer
(5,121 Views)
No, i didnt find there anything relevant to my application.
(5,094 Views)
I believe the LabVIEW drivers for that card are actually here. I believe the bottom one is the one you want.
How I found these:
  1. From the PCI-1712 page I clicked on the Manual/ Driver/ BIOS/ FAQ link.
  2. Then, I clicked on the Advantech's Drivers for 3rd Party Software link.
(5,076 Views)
i have already viewed them but how to output dual waveforms from two analog o/p channels....
Any ideas or example
(5,067 Views)
(5,067 Views)
What have you tried? A brief look at the help that comes with the driver shows a function called AO Generate Waveforms. Looks like it will do exactly what you want.
(5,057 Views)
