use queue and event to read data from two serial potr's
Hi All,
I'm trying to read data from two serial port by useing QUEUE AND EVENT but no sccusess. can some one help me?
I'm use LABVIEW 2011.
att my project.
regrads.
Message 1 of 11
(3,765 Views)
The second while loop is waiting for the first one to exit as its waiting for the cluster to become available. You need to pass the cluster through a queue inside the first while loop itself.
Search for examples that should help.
CLA CTAChampionI'm attending the GLA Summit!
Subscribe to the Test Automation user group: UK Test Automation Group
Message 2 of 11
(3,758 Views)
Hi ace and thanks for your replay.
i try todo it but still it's not working.can you take alook what i did?
regrads.
Message 3 of 11
(3,751 Views)
You need to move the cluster and bundle function inside the while loop as well and add it to the queue. Please see below
Message 4 of 11
(3,746 Views)
Hi ace,
thanks to you know it's working...but the "EXIT" button and the "clear window" not responding. why?i get error when i press them.
regrad's.
Message 5 of 11
(3,739 Views)
Accepted by JTAG
You are stopping the second loop using error cluster which means that your top and bottom loop will stop when you press exit but not the middle one. In theory you should send a queue to the loops below when the exit button is pressed and also ensure that you flush all the queues before you close everything.
Message 6 of 11
(3,735 Views)
thank you very much for your time.Smiley Happy
Message 7 of 11
(3,732 Views)
PUEDES PONERLO EN UNA VERSION ANTERIOR??
CAN YOU PUT IN A PREVIOUS VERSION?
Message 8 of 11
(3,688 Views)
Which file? and what version?
Applications Engineer
CLD Certified
Message 9 of 11
(3,676 Views)
2009
Message 10 of 11
(3,664 Views)
