user account server for licensing not reachable
would like to reactivate the license by serial number which did not work: "Invalid serial number"
tried then to log out from the account and to log in again what is not possible due to a connection error:
any idea? thanks a lot in advance
(1,440 Views)
Other than waiting until you can connect again, if you have the email from the original activation, you should be able to use the assigned computer ID number to manually activate it over the phone.
Bill
CLD
(Mid-Level minion.)
(1,410 Views)
Not just the phone. There should be an internet URL mentioned over which you can do offline activation. (Offline in terms of the license activation on your LabVIEW installation obviously)
Rolf Kalbermatter  My Blog
(1,391 Views)
thank you for the feedbacks.
finally it over the NI License Manager (separate application)
(1,330 Views)
