user defined aerospace functions/icons
Im looking to see if anyone knows of user defined (?) aerospace icons/functinos. I'd like to represent column/wheel inputs and flap/elevator/aileron outputs with representative icons (e.g surface i.e flap icons instead of just waveform graphs). Does anyone know of any ?
(2,993 Views)
Hello esctosh
There are a couple of examples that install with the Control Design and Simulation module that might help you. One is the simulation of an f14 longitudinal dynamics. The other is an example of Model Predictive Control (MPC) to implement trayectory tracker for an airplane. This examples install in
 C:\Program Files\National Instruments\LabVIEW 8.6\examples\Control and Simulation\Case Studies\Aerospace
I hope this helps
Javi
(2,984 Views)
Hi Esctosh
You may find the following forum useful for getting started with Model Predictive Control
Andrew McLennan
(2,954 Views)
Javier, thanks for your advice. I found some useful inceptor (wheel & column) icons where you suggested. What would be really cool is if anyone knows of surface (elevator, aileron and rudder icons also).
THanks again
(2,933 Views)
