using DDE to send messages to mirc
has anyone tried using labview to send msgs to an irc channel??? if so i would lie to know more.
(2,866 Views)
Hello Tomsch1,
Thank you for contacting National Instruments.
You can you use DDE to send messages to mirc if mirc supports activeX. Below is a link to an example VI using DDE to write to an Excel file. You can use this as a starting point and replace the Excel calls and commands with those appropriate for mirc.
http://sine.ni.com/apps/we/niepd_web_display.display_epd4?p_guid=B123AE0CB9F2111EE034080020E74861&p_node=DZ52049
I hope this helps,
Sean C.
Applications Engineer
(2,866 Views)
are you talking about instant messaging software or some DAQ channel? If you are talking about IM, then I can recommend a sample vi I have seen in an LTR issue. The VI uses a free web service. Search the LTR website on xml to find it.
(2,866 Views)
