using HMI/labview to design automatic drip irrigation system
Hi, every one
I'm working to design a monitoring automatic drip irrigation system, my Q. is can I use HMI/Labview to control and monitoring this system???. And how I can do that? please help.
(2,489 Views)
@zozo77 wrote:
Hi, every one
You can use LabVIEW to make a control and monitoring system, and also to make an HMI.
You start by learning LabVIEW, then make a list of requirements, then a design and then the program.
It's strongly recommended to do it in that order 🙂.
(2,481 Views)
(2,408 Views)
Most projects (examples) will be trivial (for instance for the example finder) or proprietairy (and probably not to the point).
Even your small set or requirements defines a unique set. The trick is to find the commonity between examples and your situation.
We can't specifically recomment anything, as your description is pretty wide. You only told what it's about, not the story...
(2,401 Views)
