using LabVIEW 7.0 Evaluation version
Hi all
I Installed the LabVIEW Evaluation version in "Evaluation Mode".But I've just open and created a new Vi once.When I open it again,I get an error message that it is expire.I think it just expire after 30 day.Can you help me about this problem.
Thanhks all
(2,615 Views)
Hi anhdung,
From the posts that I've read, it appears that it has to do with the system clock settings.  However, I could not open the information in the Knowledge Base.  You may want to contact NI on this one.
However, please have a look at the links below:
http://forums.ni.com/ni/board/message?board.id=170&message.id=64272
http://forums.ni.com/ni/board/message?board.id=170&message.id=46557
You may want to try what is recommended below 😉
http://forums.ni.com/ni/board/message?board.id=180&message.id=3088
Ray
(2,600 Views)
