current time in the x-Axis
Hi everyone,
I have some problems putting a waveform together that shows the current time in the x-Axis.
I tried to do it with “timestamp” and “build waveform” but it didn’t work out. All I need is some values over the current time x-Axis.
All it shows in my waveform is the time since 1904, like it always does!
Probably a silly question, but can anyone help me out, maybe with an example VI?
TNX
Message 1 of 10
(3,506 Views)
You should give the offset and multiplier to the property node for the chart.. here i have attached a sample vi
Message 2 of 10
(3,501 Views)
You could do it without any property node.
Just have a look at the attachment.
Hope this helps.
Thomas
Using LV8.0
Don't be afraid to rate a good answer... 😉
Message 3 of 10
(3,485 Views)
Thanks, for that one,
it is just wat I wanted, but in your example changes the current date to 1904 as soon as you fillin some y-values!
can you fix that?
TNX
Message 4 of 10
(3,482 Views)
did you select time and date in the time and date-control?
Using LV8.0
Message 5 of 10
(3,480 Views)
You have the current time in the x-Axis. So far so good, but your Time stays in this one second you start the VI.
It was probably my fault, because I didn´t explain my problem good. What I need is an Waveform with some y-values (every second) and the running current time in the x-Axis. So that, for example, I can see at what time of the day a peak showed up.
I hope I made it clear !?!
THX
Message 6 of 10
(3,479 Views)
Hi Becktho,
I´m such a thickhead, you are right.
Thanks for the help
Message 7 of 10
(3,473 Views)
Did you also set dt?
If I set some y-values, dt = 1 and x0 to current time, I get different times on the x-axis.
I attach a screenshot, that shows this.
Thomas
Using LV8.0
Message 8 of 10
(3,473 Views)
yes, I set dt as 1. But I don´t get what you mean with the different times on the x-axis.
Message 9 of 10
(3,462 Views)
You can see the time increase (e.g. 14:01:00.000, 14:01:05.000, 14:01:10.000).
Using LV8.0
Message 10 of 10
(3,458 Views)
