10-17-2005 03:40 AM
Hi everyone,
I have some problems putting a waveform together that shows the current time in the x-Axis.
I tried to do it with “timestamp” and “build waveform” but it didn’t work out. All I need is some values over the current time x-Axis.
All it shows in my waveform is the time since 1904, like it always does!
Probably a silly question, but can anyone help me out, maybe with an example VI?
TNX
10-17-2005 05:34 AM
10-17-2005 06:06 AM
You could do it without any property node.
Just have a look at the attachment.
Hope this helps.
Thomas
10-17-2005 06:21 AM
Thanks, for that one,
it is just wat I wanted, but in your example changes the current date to 1904 as soon as you fillin some y-values!
can you fix that?
TNX
10-17-2005 06:25 AM
10-17-2005 06:29 AM
You have the current time in the x-Axis. So far so good, but your Time stays in this one second you start the VI.
It was probably my fault, because I didn´t explain my problem good. What I need is an Waveform with some y-values (every second) and the running current time in the x-Axis. So that, for example, I can see at what time of the day a peak showed up.
I hope I made it clear !?!
THX
10-17-2005 06:33 AM
Hi Becktho,
I´m such a thickhead, you are right.
Thanks for the help
10-17-2005 06:34 AM
10-17-2005 06:58 AM
10-17-2005 07:03 AM
