using complied Matlab in Labview
I have a Labview vi that uses Matlab to do calculations and plotting by calling a matlab script in Labview.  I also have complied that same Labview vi so it can run on other machines without labview, but the machine must have Matlab since the vi calls Matlab scripts. Is there any way I can use a complied version of Matlab and a complied version of Labview  to run on a machine without both program licences?
(2,852 Views)
Hey jbirdthe3rd,
Thank you for contacting National Instruments.  From the information you have provided here, I don't believe you are going to be able to achieve this specific behavior.  LabVIEW has a run time engine that allows for this type of operation, and it looks like you have used this with the LabVIEW portion of the application.  The only suggestion I can provide in this case is to consider using LabVIEW Mathscript.
I hope this helps!  Let me know if there is anything else I can help with or clarify.  Have a great day!
Jason W.
(2,806 Views)
