using daqmx device from different parts of a vi
i want to control four testsockets with one USB-6501 in one vi. Each socket has four digital output channels.
If i run the vi with only one testsocket it work fine. When i use more then one socket parallel there is an error "device is in use".
Is there any solution to make an wait until devise is free or something like this. The other way is to use four USB-6501, but it is to
expensive.
greetings
schwede
(2,705 Views)
schwede,
you should split the hardware IO from the TestStand sequence in such a case. I suggest to implement either a dedicated communication layer which receives data from a free running DAQ VI. The other option woulde be to implement the DAQ part into an FGV (functional global variable) which receives parameter for reading and selection of the channel. So you have a single setup for the device (create a task including all channels for your test) and the providing functionality to read finite all channels and reduce the data to the channel desired. The result of the VI would be the data set of this channel.
hope this helps,
Norbert
Norbert
Expert: Geometry
(2,695 Views)
Hello Norbert,
thankyou for your fast answer. I use only LV (8.5.1) it is an standalone application.
Do you meen that i should use an extra daqmx loop parallel with a variable that is initialized by the program parts?
Have you a short example for me, please?
thankyou
schwede
(2,692 Views)
Accepted by Schwede
schwede,
ah, so this time you do not use TestStand? 😉
Ok, what i suggest is to use a functional global, also known as Action Engine (read Bens nugget carefully) in order to control the DAQ part. So it is not a parallel loop but a whole VI.
You could use a parallel loop as well, but you have to take care about the correct distribution of signals if needed.
hope this helps,
Norbert
Norbert
Expert: Geometry
(2,690 Views)
