using dll class based
hie
i am trying to use a dll based on c++ programing using  classes.
the only functiones that i can  see / rich  are the ones outside the class .
why ?
how can i rich the ones that are inside it ?
i have the cpp and the  h files . can i use them insted ?
regards
zivmer
(3,627 Views)
@zivmer wrote:
hie
why ?
regards
zivmer
You can't. LabVIEW's Call Library Node can only access global C style functions exported through the DLL export table. C++ functions are normally not exported at all but instead accessed through the method table of an object. Since the C++ binary interface is compiler dependant supporting such an interface would be very difficult for LabVIEW.
Your options are to use ActiveX instead, if your dll supports that, or write a standard C wrapper library that translates the C object methods into standard C function calls and export them from your DLL.
Rolf Kalbermatter
Rolf Kalbermatter  My Blog
(3,608 Views)
