using int pointer as parameter in dll, but the value of parameter doesnot change
Hello, I have a function in dll as void set(int * a){ (*a)=99;}
And I connect a int32 to the dll. But when I run the vi, the value of int32 does not change.
As the pic shown below:
(2,685 Views)
Accepted by percy222
You connected a control to the DLL parameter. That means the value from the control is passed to the DLL, ... and finito! You need to connect an indicator to the right side of the DLL parameter to see the value returned from the DLL.
Rolf Kalbermatter  My Blog
(2,667 Views)
Thank you very much!
(2,644 Views)
