using maths function in VI
I know it can be done in Matlab but I would like to know if there is a way/block in Labview to type in a math function to generate a plot? (for example y = sin(x) for x=0 to 6)
(2,999 Views)
Sine Pattern.vi
(2,996 Views)
You could use a formula node.  Use Ramp Pattern or incrementing inside a loop to generate the series of X values to feed into the formula node.
(2,954 Views)
Accepted by sherzaad
LabVIEW is not a "visualization" Language (like, say, Matlab, or Mathematica), it is an "Engineering Workbench" (the "EW" of LabVIEW) meant to construct "Virtual Instruments" (more letters of LabVIEW).  You certainly can write a VI that will make a particular plot, with particular parameters, but it isn't well suited (though I'm sure it could be done!) to write something that takes in a "typed-in" function and generates a plot.
(2,941 Views)
