08-19-2009 09:57 AM
Dear all,
I'm trying to use Newton Raphson zero finder VI, but till now I can't get any result from it.. I want to know the proper way to feed it with an equation.. I need it to solve a Photovoltaic iterative equation
I= Iph - Io*(exp(V+I*Rs) - 1) + (V+I*Rs)/Rp
I'm looking forward for your help
Solved! Go to Solution.
08-19-2009 10:02 AM
As mentioned in the original thread, you need to help us too. 🙂
Could you give a bit more details and possibly attach your VI and some typical data?
08-19-2009
09:54 PM
- last edited on
06-30-2026
12:22 PM
by
Content Cleaner
You could specify the equation as a formula string, such as
10.0-1.0*(exp(2.0+x*15.0)-1)+(2.0+x*15.0)/20.0-x
where x is the unknown variable which **MUST NOT** be in captial letter. And, I suppose that
Iph = 10.0, Io = 1.0, V = 2.0, Rs = 1.5, Rp = 20.0
are known coefficients. You have to explicitly code those values in the formula string.
Starting from LabVIEW 2009, the Newton Raphson Zero Finder VI has a new instance for VI reference input. That is to say, you could create a VI to implement your function and pass the reference of that VI to the zero finder VI. Moreover, you can pass arbitrary values to your function VI. By using this way, it is able to solve the problem where you want to find zeros in a loop and the known coefficients are varied in each iteration.
08-20-2009 06:58 AM
Thanks a lot for your answer, I do want to specify the equation into a formula string , but all my tries with converting the Formula into string never works and the result of the Zero is always NaN + there is an error message appears from the "Scan from String" function refering to invalid input.
would you please give an example of creating a formula string for the Newton ............ VI ?
08-20-2009 08:08 AM
08-20-2009
10:54 AM
- last edited on
07-02-2026
12:02 PM
by
Content Cleaner
Maybe this will help?
Also, you are reducing all your inputs to a single DBL. How is the subVI supposed to know all the variables?
08-20-2009 11:11 AM
08-20-2009 08:12 PM - edited 08-20-2009 08:14 PM
08-22-2009 09:03 AM
thanks a lot !! , only How do you input the a,b,c,d... variables into the for loop ? I couldn't find this string table in my Labview 8.5 ... can you give me the right name of it ?
08-22-2009 10:12 AM
