‎06-18-2014 01:51 PM
Hello all,
I am using an ni 9401 Digital I/O module with an ni cDAQ-9178 Chassis. I would like to connect two mass flow controllers made by alicat to the 9401 module, and read and write to said controllers. The controllers use a serial rs232 connection, and I had vis built with the assistance of another community member that allowed me to communicate with them. I have made an adapter that connects the 2 9 pin cables to the 25 pin port on the 9401 module. I also know which specific pins are used for input and output to each controller. What would I need to do to control my controllers in this manner?
Any help is greatly appreciated
Thank you,
yp21
‎06-18-2014 02:26 PM
Hi yp,
if you insist on using the 9401 module to communicate to your MFCs you need to make your own routines to replicate the RS232 protocol. And you need some electronics between your 9401 and your MFCs to convert the different voltage levels on both ends of your RS232 cable: 9401 uses TTL, MFC expects ±12V…
‎06-18-2014 03:01 PM
‎06-18-2014 03:57 PM
I plan on adding more instrumentation to my experiment, and having a chassis with interchangeable modules allows an easy ability to do so. In regards to the voltage difference, is that for the rs232 input and output connections?
‎06-18-2014 04:00 PM
Hi yp,
just read the Wikipedia entry on RS232. It also explains the voltage levels an RS232 input expects. Then compare those information with the specification of your 9401 module…
It's all basic information easily found on the internet!
‎06-18-2014 04:18 PM
