using same string indicator in different stacked sequences
Hi guys, I want to use the same string indicator in different stacked sequences. I tried to wire the output of every string constant through the sequence to my string indicator outside the sequence block but then I get an 'Wire connected to an undirected tunnel' error. What is the best way to use the same indicator for all the sequences?
(5,374 Views)
Accepted by JoVMo
Hi JoVMo,
You can simply use a Local Variable of that indicator inside the sequence..
Nitz..
(Kudos are always welcome;))
(5,366 Views)
Is this what you were looking for? If so, mark it as a solution so that it would be helpful for others.
Nitz..
(5,358 Views)
Here is another option to avoid local variables (VI attached is in LV 8.20)
Hope this helps.
We have two ears and one mouth so that we can listen twice as much as we speak.
Epictetus
Antoine Chalons
(5,355 Views)
Hi Jo,
"to my string indicator outside the sequence"
This is a typical problem, when not understanding the dataflow paradigm of LabVIEW! Obey the dataflow! (And maybe go here...)
"What is the best way to use ... for all the sequences?"
Next typical problem when not understanding dataflow: you don't need sequences at all when properly using dataflow programming...
@TiTou:
Problems with copy&paste? Smiley Wink
(5,348 Views)
@GerdW wrote:
@GerdW wrote:
@TiTou:
not even 😮
@GerdW wrote:
@TiTou:
not even 😮
see : http://forums.ni.com/t5/Feedback-on-NI-Discussion-Forums/Text-lines-and-images-get-duplicated-when-I...
Epictetus
Antoine Chalons
(5,340 Views)
